QUOTE (Richard Johnson @ 24 Oct 2008, 22:49) <{POST_SNAPBACK}>*** I knew that Zmil - Every one will have a different opinion and thats what I'm looking for. I was only making the point that while the announcement isn't really a driving sound, its actually well used by owners.
In the end I will end up with a set of defaults that can be changed case by case as needed. There are always more on the decoder than are actually activated, so its actually possible to happily customise set-up for each client anyway - just a matter of moving each into or up or down the function list.
I was actually very surprised at the degree of interest in the station announcements myself - I think its one of those things that is a bit different so the owner can trigger to impress the guests, and to be honest with the echo and equalisation adjustments I've done to it is really does sound like its coming from a station not the loco!
With the equalization is the EQ adjustment done within the Lokprogrammer program or do you use an external sound program like Sound Forge etc
QUOTE I'm currently trying to work out a way of creating a whole set of them so I can match to each region and modellers needs.
I can Imagine - "I need an announcement saying " Hogwarts Express leaving Platform 9 and 3/4 at 11.00am""
QUOTE I'm scurrying around right now trying to re-find a website I once had bookmarked that took a recording adnmorphed the voices to different national / regional accents to add authenticity. The alternativeis to have MRF membersmake one up is plain language and email me a MP3 or Wave file of it so I can tweak it with the same effects....
Actually I think some of the added features on the sound decoders such as the odd pump or similar will end up going (actually still there but put in a position past Fn 9) as they are also often already heard often enough in the start and random settings.
BTW The momentum in your loksound can be set to toggle OK - but with a handset its really not an easy thing to do.
If you want I can do it for U if you drop in - it'd only take a few minutes to do - the kettle wouldn't even have time to boil
Hi Richard
Re the momentum toggle
I'm not really a fan of wheel spin (anymore) Different when young and foolish , burning rubber on tyres!
I had one Lok (BR 218 for Brian's benefit) which I had forgotten to add values to cv3 and cv4 so even at the default of 1 on the TCS pre- BEMF decoder -Quick acceleration or a change of direction caused wheel spin (and would have removed the traction tyres ) So I changed that next time it went on the track.
Sound is a colourful addition to Model Rail , I think that it should be subtle and not over the top , a bit like weathering .
Someone said to me , "wont the sound of the coaches on the track drown out the sound of the lok if you turn it down to much" I thought about this. Then I recalled what you hear as a train passes first you hear the Engine , as that passes by you hear less of the Mid to High frequency's and more of the Low throb of the motor ,which is then overpowered by the clatter and clank of the wagons , but the low throb of the Loco is still there.
With the v100 (br212) Lok the Loksound decoder has a lot of headroom for the main sound ( I turned it down to 14 ) so there is room to add a bit more low range sound without distortion and I think an external system like Rail road and Co 4D sound would be a good addition (just to expensive for me though) Maybe someone will do something through JMRI that will utilize the computer to run additional sounds , like Station Announcements , Clock Towers , Church Bells , Cows and Livestock, Road vehicles and the general background sounds of your scene.
I'm probably dreaming there though
Regards Zmil
Hi Richard
Regards Zmil
