QUOTE (zmil @ 5 Sep 2008, 10:30)
<{POST_SNAPBACK}>Hi Tutorlane
There are decoders that will plug in to the Tortoise Point Motor
Some have feedback to the DCC system (more expensive though)
DCC Specialties do some- Here is a guide
Click Here
These are quite common in the US and suppliers do combo packs of Tortoise and DCC decoders
the Lenz 150 only needs a simple addition to run the Tortoise type motors (2 diodes like 1N4001 ,cost 6c ea)
and run a separate AC power supply , to the AC input of the LS150
You can also still operate the points with momentary contact push button switches.
Hope this helps
Regards Zmil
***Tortoise only draws 10 to 15 mA so its like cracking a hammer with a nut using an LS150, also a tortoise is a stall motor which should really have power permanently to it not a short burst. It is also much quieter with lower voltages, and runs really well at 6~9 volts.
easiest and cheapest is a DPDT switch and a wall type plug in pack for power.
next most economical is the NCE switch-8 which as the name suggests will control 8 of them
NCE switch-it will control 2 of them, but has enough go to power two on a crossover from a single output.
