Hi Swingcats,
Which crossing you use is also important. The long crossing (SL-394F) is set at 10° which is the same angle as all of the Peco FS points and is ideal for making a crossing between 2 parallel tracks. The short crossing SL-393F), however, is set at 20° which makes for a more oblique angle of approach. You might also wish to consider the Scissor crossing which is an excellent piece of kit and ideal for a station throat.
In any event Al is absolutely right in saying that you should, wherever possible, use the longest points you can fit it since this not only looks better but, as the radius of the turnout track is larger, trains will run over it much smoother with less risk of derailments.
Expat
