QUOTE (steamrailuk @ 25 Aug 2008, 17:48)
<{POST_SNAPBACK}>.. it claims that this loco can produce 5000 horsepower and to my astonishment it can reach 120mph. Can a loco of this size be capable of running almost as fast as Mallard?
I know locos that have small diameter wheels are capable of high speeds as I've heard stories that Evening Star could haul expresses up to 90mph, but is it possible to reach 120 without causing serious damage to either loco or track?
The power output is nothing extraordinary for the final express 'superpower', and should be adequate for the speed claim. For comparison the NY Central's final brute the 4-8-4 'Niagara' was good for 6,000hp. The Chessie laid some of the heaviest rail used in the steam era, capable of accepting the 42 ton axle load of their H8 2-6-6-6 simple mallets (a freight machine with an output over 7,000hp), which may well have enabled the track to stand the pounding of the J3 4-8-4. The 72"wheels are a bit on the small side for the ultimate in speed; the Hiawathas had 84" and quite definitely ran over the 100mph mark in daily service,
simply to make schedule. These likely were the fastest ever steam locos in regular service. Somehow it never occurred to anyone to formally time one at full chat...
Quite how well the loco stands up to the battering long term is just one reason why I have my doubts about the 5AT project. The US experience in the final 'superpower' locos weighing around 200 tons was that a cast steel frame with integral cylinders was the way to go. Their experience showed that built up constructions were worked to failure by the piston thrusts of around 80 to 90 tons, alternating each side, bending the frame. Trying to accomodate the necessary 50 ton or thereabouts thrusts within the 90 ton all up 'envelope' of the 5AT is going to be challenging in the extreme. Compare to the UK experience with locos that were called upon regularly to put out approaching 2,000hp: the Princess Coronations suffered from loose cylinders throughout their career, the A4's were noted for deforming their frames: and these were 4 and 3 cylinder designs, not 2 cylinder. The US designs have roller bearings on the axles and the coupling rod pins; more weight, but necessary to stand up to the hammering. The rod cross sections have to be heavier to house the bearings, more weight required for rotational balance...
The final developements in US steam power make fascinating reading, and much of it is now on the web. 'Why didn't the PRR duplexii succeed?' is always a good one!
