QUOTE (Edwin @ 15 Aug 2008, 18:50)
<{POST_SNAPBACK}>The metal used to make the rails is known as nickel silver, however it doesn't include any silver and it is actually a type of brass and like other brasses it is yellowish in colour. It may be more yellow if it needs cleaning.
The way to get round it is to paint the sides of the rails a greyish-brown like the prototype. It is then very difficult to tell that the shiny strip on the top of the rail is a slightly different colour from the steel of the prototype.
***Small correction - yes, it uses some of the same elements but isn't a brass derivative....It is most commonly made of nickel, copper and zinc + minor parts of other elements. High quality NS uses more nickel and zinc and less copper.
So
The best quality NS rail has a high nickel content - C&L use about 22% nickel and a relatively high zinc content and as a result it looks much more like steel and tends to corrode less.
Coin grade NS is about 25% nickel, your Peco rail is 18~19% at best, so quite yellow even when clean. even a couple of percent morenickel and a little more zinc makes it nearly stainless and if Mfrs would simply make that small change you'd all have to clean your rails less!
Personally I'll stick with my preferred steel rail.
Less cleaning needed and it looks like steel rail should.
to quote wikipedia re NS
Many alloys fall within the general term of "nickel silver". All contain
copper and
nickel, while some formulations may additionally include
zinc,
antimony,
tin,
lead or
cadmium. A representative industrial formulation, Alloy No. 752, is 65% copper, 18% nickel, and 17% zinc. In metallurgical science, such alloys would be more properly termed
nickel brass. The white alloy of 75% copper and 25% nickel used in coins, such as the
United States nickel, is better known as copper-nickel, cupro-nickel or
cupronickel.
Some nickel silver alloys, especially those containing high proportions of zinc, are stainless (
corrosion-resistant).
Re the black stuff on the rail..... (you know, the black line on your finger when you rub the rail). I had it analysed some time ago - its nearly 95% copper oxides, which is why the yellower the rail (the higher the copper content) the more it will need cleaning.
DCCconcepts
