Hi All
The last couple of conversions I have attempted , I have used a piece of left over transparent plastic from a blister pack to mount the decoder on. Initially (the first job was a small BR24 with nowhere to mount the decoder , but the space in the boiler) it was to give the decoder a flexible mount and stay in place when slipping the body over the chassis. Also the double sided tape adheres to the plastic much better than trying to stick the tape to the loco's weights
Let me know what you think.
Fleischmann HO 4224 BR260
Installation of a M1 Decoder
This is an all wheel driven locomotive with power pickups on 6 wheels
The best method to disassemble the locomotive is to stand it up as normal
The 4 buffers hold the front and rear rails and the body too the chassis, be aware there are 4 little plastic Lamp covers which will likely fall off when the railings are removed. The body can now be lifted straight up.
Here is a picture of the "naked" locomotive.
There is a nice spot for and M1 or MC2 decoder without having to resort to milling of the loco weights. I chose to use the M1.
The picture above shows the view of the side of the Locomotive, Positive rail to the near side.
The Motor back plate was replaced with a Fleischmann insulated version.
The Decoder was mounted on a piece of plastic (from a blister pack) to fit in the space shown in the previous picture. Utilizing the motor mount screw to hold the plastic in place, this allows the weight to be removed without disturbing the decoder wiring. Fleischmann's original Black wires from the +ve side pickup were retained and connected to the Red wire on the original tag. The Black wire to the -ve (chassis internal pickup) was grounded to the chassis with the rear light. As the chassis is "live" from the -ve pickup I chose to run the lighting on half wave power.
(I Know Richard would not Approve)
Body back on , fitted with Profi couplings , the inside ends of the body was lined with Al foil to stop the lights shinning through
This loco runs very well on DCC with BEMF
Regards Zmil
Regards Zmil
