QUOTE (Smokeyone @ 12 Jan 2008, 14:27) <{POST_SNAPBACK}>Is anyone familiar with adding capacitors to zimo decoders so that the loco continues to run over dead track sections.
I understand that it only works with Zimo and not any other make but perhaps someone knows better.
*** if you are competent with a fine soldering iron it can be done to any decoder.
The capacitor plus a diode and a resistor are simply placed after the bridge rectifier on the decoder.
It is not for the faint hearted to do and frankly not necessary if track is well wired and clean and pickup adjustment is done properly on the locomotives. You will need to be able to correctly identify the soldering points too of course. Bear in mind the warranty will be zero if you make an error - I strongly recommend that unless you are VERY good with the soldering Iron you focus on fixing the problem at its source - the pickups and trackwork.
For those who would like to learn more, a good friend has a website which shows a couple of examples - here is the link
http://www.members.optusnet.com.au/mainnorth/alive.htm
