Hornby Select
2.7K views 5 replies 3 participants last post by  Richard Johnson
#1 ·
Hi Guys,
I am attempting to alter the direction of locos (not movement, but the setup say like, if the loco is to go -> then i have to click <- on the control). I hope thats made sense. I followed the instructions (holding down the unlit direction button) but nothing happend. Here is a link to the manual
http://www.google.co.uk/url?sa=t&rct=j....43287494,d.d2k
I contacted Hornby customer support a week ago but they havent replied.
Allan
#2 ·
Allan,
Could you clarify
1. When you do the change direction button does the button light for the change of direction but the loco dosen't change direction.
2. Do you have control in that the loco only moves when the knob is rotated.
3. What decoders do you have fitted.
The select is notorious with US and some other decoders. Usual sign that I have=seen when asked to help is loco moves immediately and no control over speed and unable to reverse direction.
I am of to run a scratch modelling class now but if you reply to the items above it will help others who will help. I will check later tonight to make sure someone else has helped.
Ian M
#3 ·
QUOTE (enM @ 7 Mar 2013, 17:21) <{POST_SNAPBACK}>Allan,
Could you clarify
Ian M
Hi.
Its the overall direction. I have quoted what it says in the manual:
It is a commonly accepted practice in the United Kingdom that when a locomotive is in operation, other than when
shunting, the front of the locomotive normally faces to the left.
''This is easy to determine when operating steam locomotives but not quite so obvious where a diesel or electric
locomotive have double cabs. As a rough guide the front of a diesel has the roof fan closest to the front, while
an electric locomotive's front is determined by having the pantograph furthest away.These are general guides
but are not necessarily absolute.
After assigning an address to a Locomotive, it may not move in the direction indicated by the green LED on the
control unit.This can be corrected by the following procedure.
Correcting Locomotive Direction:
1. Ensure the locomotive is stationary.
2. Press and hold the unlit direction key (<- or ->).
The LCD will display either "Fd" or "rd" for one second.
The red LED will flash twice.
3. Press the unlit direction key.
The green LED will illuminate below the button.
4.Turn the Control Knob clockwise to move the locomotive.
5.The locomotive will now move off in the corresponding direction.''
Allan
#6 ·
*** The use of < and > are totally irrelevant with DCC. They have relevance ONLY in DC running, where track polarity dictates direction.
Hornby's attempt to link loco direction to the < and > of the controller is simply very naiive, uninformed and incorrect thinking. They should more correctly have labelled them FWD and REV.
Forward is relative to the loco front, so if you press > and it moves forward relative to the loco front, then pick it up and place it back on the track facing the opposite way around, it will still move forward relative to the loco front with the controller set to >
