QUOTE (Graham Plowman @ 4 Aug 2011, 00:33)
<{POST_SNAPBACK}>Signalling in the UK was and still is predominantly on the left, except those regions such as the GWR who had right-hand drive locos where the signalling was on the right. Since the end of steam, the WR has converted to left positioned signals.
I'm sorry but, no, this is incorrect. Neither the GWR nor any other UK company or subsequet region signalled their lines "Normally on the right".
Once the BoT had Regulatory powers (from 1889) they recommended that
all signals should be placed to the left side of the line (as the movement approached them) to which they applied or no further to the right than over the centre line of the line to which they applied.
This was a recommendation
not a Requirement. Consequently companies were able to locate signals on the right of the line to which they applied when it was appropriate. The usual definition of "appropriate" was when sighting from 440yards made it necessary. I have seen many locations where this defintion would seem to have been stretched however.
Consequently the following is basically correct.
<{POST_SNAPBACK}>However, at the end of the day, the actual positioning comes down to driver sighting: signals are positioned where they can best be seen by a driver. In most instances, that is on the left, but sometimes it may be on the right and other times, elevation may be used as well.
Graham Plowman
It should be added, however, that "All signals" meant "all Running Signals". Non Running Signals tended to be placed where they were best seen or not in the way. (Running Signals are Stop Signals and Distants used in Block Working on Running Lines. Non Running Signals are all the rest).
A Stop Signal with - Slotted - Distant beneath it (such as the OP describes) would occur where the Stop Signal of one Signalbox fell within the braking distance of the first Stop Signal of the next Signalbox. The Signalboxes do not have to be Block Posts - although more usually one of them at least would be.
Where things are very close the Inner and Outer Distants of the Box In Advance might be slotted under the last two Stop Signals of the Box In Rear. For example the Outer Distant might be under the Home Signal while the Inner Distant was under the Starter of the Box In Rear). In that case the Inner Distant would be Slotted by the Starter but the Outer Distant would be Slotted by bothe the Starter and the Home. Where the Distants were on seperate levers the Outer Distant might also be slotted by the Inner Distant to ensure that it would only ever clear when everything ahead of it through the Signalbox to which it applied was showing clear.
Any... Most signals in the UK are on the left of the track to which they apply on all companies and subsequent Regions.
