How Torrington came about.
I moved to Devon just over 3 years ago and was lucky to find a house that had a room that was big enough to have a layout.
For years I wanted to build a model railway, but never had the room or time to do one, I spent some years playing around with Trainz on my pc.
When I moved into my new house, I set about looking at lots of different lines in books, but I could not find anything that would fit.
One after noon I was in Torrington and saw that Torrington museum was open, having some time to kill I wondered in, looked at old farm equipment and photos of Torrington over the years ,until I came across one glass cabinet !.
Within this cabinet was photos of Torrington Station and the original track plan! Dated SR 1935.
Well that was it, I had found what I was looking for, and next I went off to the library.
Here I found a book called Lines to Torrington (This book I had out of the library for over a year)
This book had a track plan and signal diagram and photos of the building that where their.
Torrington had every thing I was looking for in a model railway, a nice amount of passenger traffic and goods, especially the milk traffic.
I spent a few months working out how I was going to lay Torrington out and getting as much back ground info I could find, I even found a set of post cards in the post office that had a lot of photos of Torrington station.
I need some wood
I ordered the wood, so I could make a start on building the base boards, all the base boards are made on 9mm ply, with 2 by 1 frames.
I made the legs 40 inch high, as I did not want to have to bend over when working on the layout and when sitting down, you get good eye level with the locos.
The layout is made from 3 boards, 4 - 2 feet and one board 3 feet long , I put aliment dowels in when I was building it so I could take it apart and work on each board on its side ,this made putting the wiring in a lot easer .
All the track work is code 75, which I laid down using drawing pins, as I could move the track around until it looked right.
Once I had the track down I started work on all the wiring for the layout, this is one area I wanted to keep it very simple ,my first attempt blow my controller up ! .Doha!
Once the track was down I tested it for over a month, before I even put any ballast down, just to make sure all was working as it should, I did have to rearrange a few things and I did add some more isolators in to the track.
Once I was happy with it I then ballasted the track ,for the running lines I use N gauge Ballast and for the yards and shed areas I use yard ash from C+L , in the shed area I mixed in with the yard ash ,ash from my coal fire .
The track was down;
Next I will tell you how I went about doing the buildings for Torrington.
Until then keep on modelling
All the very best
Darren
I need some wood
The track was down;
All the very best
Darren
